Ed5275
anyone not able to connect to Verizon visual voice mail with this rom? It just stays on "checking account status"
Yeah I have this issue as well.
Hey so quick question for anyone that would know but I could have sworn that when I first flashed JB, the notifications were expanded by default in the notification bar. Now for some reason they're always in the ICS style. Does anyone know how to change this? I like the expanded versions and would rather not have to do it manually each time
So I flashed this ROM last night and everything has been working perfect. Shout out to Wugs toolkit, as I've never flashed a ROM before and as a total noob, I found his tool and instructions to be outstanding.
Today, I go to pair my phone with my car, and the phone and car aren't detecting each other. Prior to the flash to JB, I never had any issues with pairing my car (Infiniti G37) to my phone. The phone seems to detect other devices, but the car and phone don't find each other....
Anyone have any advice?
I've found with my car that I have to delete any old pairings when I install a new ROM. Don't know that it will help you with your problem. With that one exception I've never had a problem with this phone.
Viper i agree with you. When i first flashed i noticed that they were expanded ny default. I dont know that theres any way to toggle that. I have to wonder if it wasnt enabled by default at first to make sure ppl noticed it. The only thing i can think is maybe it will stay around if used regularly?
Just give it a chance to sync up with Google and they should all start downloading. Then they'll all have to update. Best to connect your phone to a reliable power source, set the display sleep time to 5 or 10 minutes (don't forget to set it back when you're done), and let it do it's thing.Just flashed the ROM as my first time rooting my phone and I love it! Everything is so fast and smooth. Unfortunately, my apps aren't re-downloading. Do I really have to go through every one and manually hit install? I unlocked/rooted using Wugfresh's tool and did do a backup of my apps + data. Can I restore that even though I'm now running JB instead of ICS? Thanks so much.
You can go to the Play store on a PC browser, log into your account and see all your apps that you've previously installed, and then re-install them individually. I found that much easier than doing it on the phone. You won't have your saved data or anything though, so you can try doing a restore of your apps. I'm not sure about going from ICS to JB, but I can't see why that would be a risk.
Thanks guys! Well I finally left my phone alone to go to sleep and when I woke up, nothing had installed. Luckily (or not), I had spent the better part of the night manually installing each app I considered to be noteworthy.
@Nessthis, that was the first thing I tried last night. It said my app would install and appear shortly, only it never did. Were you able to get it to work?
Thanks, I may give it a try later. But for now, it was nice going through each of the apps and seeing what I really needed and what I didn't. This ROM has been awesome so far! I do miss some customization from Nova, but it seems that others have been having trouble with it so I won't try it out just yet.
Nova seems to be working great for me so far! Gotta get my backup from my home computer when I get home, but I should be up and running like before. Another note, the circle battery and softkey mods are sweeeeeeeeeeeet!
A quick google search resulted in this in 0.9263584 seconds![]()
With the exception of having to do the youtube fix everything seems smooth. Found circle battery mod if anyone is interested.
[MOD] [4.1.1] Jelly Bean Circle Battery Mod - Galaxy Nexus Themes - RootzWiki
Rom pete_toro_ota_2012-07-19.zip just posted. -Ryan
