[Verizon] [ROM] AOKP JB-MR1 Milestone 2 [4.2.2] (07.21.13) TORO
I'm on the 8/5 build and it slaughters battery. Where do I find these more recent builds? Is this zero guy on rootz forum? I haven't seen that on the site.
androtransfer.com
There was an issue with the new "flip over" feature causing ROM Control to use a lot of battery. It's fixed in the 8/8 build on the site above.
Rpm control popped up but I had good battery on 8/5. Now on 8/8 and answering a call the icon is not aligned correctly. Anyone else?
Yes, noticed that but I run with an LCD density of 241 so assumed it was because of that...
Glad I'm not the only one. Anyone know how to correct? Can I just extract the phone.apk from 8/5 and install in 8/8 to fix misaligned answer icon?
Running 8/5 build and ROM control says its killing the battery, but, I got great battery life today. I'll stick with this build since it seems that 8/8 has some minor bugs...
If you look at rom control its only running for a few seconds. Never hurt my battery. 8/8 runs great except answering
flashed 8/8 last night. works great, no more rom control battery killer, and the weather does work (for me) on the lockscreen.
What are the steps to dirty flash. It has been a while.
Wipe dalvik
Flash rom
Flash gapps
Anything else?
What I do to dirty flash:
1. Wipe Cache
2. Wipe Dalvik Cache
3. Wipe System
4. Flash ROM
5. Flash Gapps
6. Wipe Cache/Dalvik Cache
7. Reboot
