Does anyone have an issue with the keyboard covering up the bottom portion of the text popup when using handcent, or am I the only one? Didn't have this problem until after I flashed 4.2.1.
No other comments on the pop up problem with Handcent? Does anyone use Handcent and NOT have this problem?
Can someone test there ability to tether their Xbox to the native tethering on this ROM? So far I'm 0 for 2 with other ROMs. It's seemingly a 4.2 issue, and not a ROM issue so I'm looking to confirm this (
Can someone actually try this, not just say you are good to go or not... please actually try because this sucks...
How's battery life?
My first rom flash!
stock 4.1.1 has been buggy since the oem update, so I decided to factory data reset it... it worked my better, but since my phone was now clean, I decided to start trying some roms. AOKP was my first choice. Plus say that a new build just dropped. very cool.
aokp blog says there will be bluetooth problems, but i dont really use bt... everything seems to be working well.
I didn't like the notification transparency either, and it took me a couple of goes before I got the settings to take hold, but did finally get it back to black.
Only thing I would change is to have the Rom obey the animation settings in the developer settings section. I absolutely hate the power off animation when clicking the power button... I like to set it at 0.5x as it disables that anime but leaves the others on, at least it did in stock 4.1.1.
Lol I love the power animation....
hope all is well over here and I've already got a 4.2.2 unofficial toro build cooked up if anyone would like it (and jmar permits it, of course).Hey all, just checking in...know I haven't been around lately, but that's because I switched over to T-Moblie and got the N4hope all is well over here and I've already got a 4.2.2 unofficial toro build cooked up if anyone would like it (and jmar permits it, of course).
Cheers,
andoird213 (formerly: Patriot123)
