Thanks, I followed your recommendations and dictation works again. Now I am wondering if I should even bother w/ tibu. Afterall, it doesn't take that long to reinstall everything from the play store. Thank You jmar!!!
You're very welcome!
Here are some rules that I follow in terms of TiBu:
I use it until a clean install of a ROM and user apps+data produce bugs when flashing a new version of the same ROM, unless the update also includes a version bump (i.e. 4.2.1 to 4.2.2).
If flashing a new ROM from a different Dev, I will 'only' restore user apps. Sometimes I restore data, too, but leave my expectations at the door...
...for an app that costs a lot I know it can be disconcerting that it doesn't always "work." But here's the deal...
...when flashing ROMs, a couple things can affect the install...
...some Devs mod the framework-res.apk or framework.jar files amongst others. Due to this modding, the way that a backed-up user app worked in the same/one ROM may vary in the next version/next ROM. It is a part of living in the world of flashing.
So, what does this all mean?
Keep your internal storage backed up regularly so you have it to restore in case anything goes wrong.
Make nandroid backups to secure your last known fully functional install.
Lastly, when you've covered your bases, have fun and, remember that, if you use these powerful tools to its fullest extent you'll never go wrong.
Hope that helps,
jmar
