[Verizon] [ROM] Codename Android for JB (updated 10/2)
So you're running CNA man? I am to, although not the nightlies. Installed a nightly a few weeks ago and had major lag problems. So still using 3.5.0 stable.
Yup, since 1.0
I think I have seen lag here and there, but I am a dirty flasher. Have noticed lag has been nonexistent since about 3.3
Yup, since 1.0
Cool. I may switch to nightlies at some point, but just rocking with 3.5.0 stable for the being. To much going on in my life of late. :(
almost pulled the trigger on flashing the 9/18 build last night, but since a clean flash is required, will try to do it tonight
Well, took me forever, but found my first bug. The 091212 nightly is where I tried the Navy bar ring targets, so not sure if this is in others as well.
If I set any of the targets to be the Camera, it will work only if the camera app has not been previously opened/ isn't still open. For example, if I restart and slide from the Home button to the Camera, it will open. However, if I back out of the app and attempt to use the Camera shortcut on the Nav bar ring again, I get nothing. As long as I use the Regents and kill all function, I can use the shortcut again. Location (top, left, right) does not matter.
Count this one as fixed in the 9/18 nightly!
2 hours ago via Twitter:
Codename(Android) said:
Codename Android Updated to Android 4.1.1_r6 (JRO03R)
Update tomorrow. Builds will run throughout the night for all the usual devices and a brand new family member the International Galaxy S3 :)
Sorry to hear that, bro. The 9/18 one is quite nice. According to Colchiro's quote, we'll be seeing even more soon.
Thanks man.
So to start flashing nightlies, would assume that I should do a clean install from the get go right?
I am still on 3.5.0 stable.
Nothing yet. I guess this means the update will be available tonight (instead of today). Seems to me it starts at 8 p.m., but takes a couple hours.
Updated to 3.6.0.
Will have to see how it goes once I dive into it. Only thing so far that was kind of annoying, was the I was not able to install apps via the web. It just said in the Play Store that I already had the apps installed, and there was no choice in the dropdown box to force it. It was there but grayed out.
