kinfolk248
I see several have mentioned 4.5 is faster, faster in actual use or faster b/c of the clean wipe cleared everything?
@Rubber Ducker, have you tried to download anything from the store? I had/am having problems with the store. It sees all my apps, but I can't update any or even download anything.
The pull down can be changed to another pulldown.... animated or static.... But no way to change the animated pulse speed.
So what's stock in case we don't like what we select? Blue Glow? I'd hate to re-flash the ROM just for that...
Now if we can just get the camera mute sound back![]()
Look in the folder /system/media/audio/ui the camera shutter sound to .old or what ever and its no longer active...or even replace it.
Thanks for the tip!Look in the folder /system/media/audio/ui the camera shutter sound to .old or what ever and its no longer active...or even replace it.
Thanks for the tip!
However, I can't rename it. It gives me an "operation failed" message when I try, even though I have root.
Does anyone have a silent .ogg file?
Thanks for the post about that. I wasn't even aware of this amazing feature!I love the new way you can swipe up to show the nav buttons and then they hide automatically. Thanks for a great ROM as always.
That must be it. I don't have Root Explorer so I'm trying to figure out how to mount it another way.Did you mount the system R/W (Read/Write)? I believe it's Read Only (R/O) by default. Root Explorer will mount it R/W, then long-press the file and rename with a .bak on the end. Remember to mount it R/O when you're done.
.Just clean installed 4.5 and setting up.
I see where to set up the nav bar widgets in the nav bar menu. But it doesn't look like any of the nav bar buttons can be set up to trigger the widgets -- am I missing something, or is this still a placeholder?
Also, any plans to bring back the custom brightness settings? I'm talking about the table you were able to edit where you could set the screen to be a certain brightness when it's in a particular range of ambient light.
Thanks for all the great work!!!
