Bought Root Explorer and changed it no issue. Four bucks for one feature kind of sucks though.
There are at least two other free apps there will remount / and /system as r/w and/or r/o:
- ES File Explorer
- and one other really cool one
Cheers!
the google now cards... they are a drain... always running in the background
if the google now is active, it is the same in all roms...Is that something that is just in Sourcery or in all 4.2 ROM's? Just to test things out I switched to the latest version of XenonHD last night with Franco's kernel and after 14 hours today of the same usage I am at 71% battery. I love the Sourcery rom, but can't handle the battery drain.
If you chose to use it, you'll just have to launch Now, go into settings, and turn it off. It will revert to normal search.How/where do I disable it and check to see if it is enabled? Is it on by default in Sourcery?
Thanks for the suggestions, although a little late since I already purchased the program.There are at least two other free apps there will remount / and /system as r/w and/or r/o:
- ES File Explorer
- and one other really cool one![]()
[check my signature
Cheers!
Thanks. I like Google Now, but I use it so little, it's not worth the drain.If you chose to use it, you'll just have to launch Now, go into settings, and turn it off. It will revert to normal search.
Just beamed from GNex running sourcery 4.5 to nexus 10 running AOKP Chief
Welcome to my personal Hell! I've been kicking that football around for weeks with no success. Sammy decided their version of beaming should be proprietary and only work both ways between two S3's (bas%$#ds!). Finally gave up and started using Tapestry and Bump. If you find out how to get this to work, I'm all ears!I beamed a photo from my phone to an S3 but when he tried to beam to me it sent me to the play store for an app that wasn't there. Strange.
