4.7 runs snappier than 4.6
Okay, I'm on 4.8 and I know that Eagle worked hard on new features... Heck if can find them, as I do notw what's new... I would love a hint from the devs![]()
Sent from my Galaxy Nexus using SwiftKey Flow
Chief,
Can you get the old clock from 4.1 to work? I've been copying your method of importing the old clock apk into all my 4.2 ROMs but it won't work on 4.6 nor 4.7. Are you able to get your old clock to work with 4.8?
Yep. All day long.
It's a very particular process: after the flash, there are a number of reboots required for me: As soon as I get to the home screen, I reboot into recovery to flash Titanium Backup into the app drawer; then once my stuff is restored in Titanium Backup, I have to reboot again. And THAT'S when you need to do the work.
DO NOT RESTORE Clock (ALARMS) in the Titanium Backup restore. De-select it. Once everything else restores, reboot the phone and then open Root Explorer (if you're letting it all come in from Play, wait until it's all finished).
In Root Explorer, copy the 4.1 Deskclock from its position, navigate into System/app and press Mount R/W. Long-press the existing 4.2 Deskclock and rename it deskclock.apk.bak and then press "PASTE" to put the 4.1 Deskclock in there. Mount R/O and back out.
Reboot the phone so the app "takes".
NOW go into Titanium Backup and restore the Clock (ALARMS) if you wish. Reboot AGAIN.
When it comes back up, you should have the 4.1 Deskclock in the app drawer, so you can put it on a homescreen, etc. and all your alarms intact.
Hope this helps
Thanks for the detailed post. Yea I am able to get the apk copied into the system/apps folder and reboot and am able to get the 4.1 deskclock into my widgets upon a reboot, however once I add the widget to the main screen it will not open once I tap on it. I have no clue what I'm doing wrong. All the permissions, I believe, are set correctly (r/w). Man I don't know what I'm going to do without that alarm..
Downloading V5.0 now and going to see if that fixes it, but am doubtful...![]()
there is an app clockics by mobilynx on play that works well too...
