tdevaughn
Android Expert
yesRecommend a dump and redo??
I dont think so... have to go into settings and language/input and click on the settings of the keyboard
Are there any standard gapps for this, or are there only inverted
It doesnt for me.. not sure why some see this issue while the bulk of the users do not. Try grabbing a logcat next time it fails.. betting there is another app working on conjunction with this that I dont have loadedTdev:
I figured it out. When pattern lock is selected it breaks the lockscreen security choice.
Weird, getting a force close on the lockscreen security and settings selection in settings. Anyone else?
This is on a clean install too, FYI.
Per T-Dev's recommendation, I am trying various kernels in Tools in an attempt to clear up my Bluetooth issue. So far I know that Trinity and Popcorn kernels send my Nexus into bootloops. On Tiny kernel now, and it's still breaking up.
This isn't a connectivity issue, as it breaks up on both 4G and wifi, with the phone MAYBE 3 feet from the headset. I normally get a 50-60 foot range.
I hate to think I may have to revert back to 4.5 or 4.6, but Bluetooth connectivity is vitally important to me. If anyone has any ideas, I'm ready to try just about anything here...
Hey Triton, agreed...see my previous post. This was my experience in replicating the problem too. I could get and undo the forceclose by turning on and off "patternlock." I wonder if Chronos has something to do with it. Do you have that loaded?
Two questions for the Dev team:
#1 What kernel was used for 4.5, does it work with 5.0, and where can I get it?
#2 I suppose the little "present" in IRC can be flashed with a cache and Dalvik wipe?
Thanks
EDIT: Okay, I was under the obviously mistaken impression that the Magic Clock UI controls the DeskClock. However, I un-bolded everything there but that stupid 4.2 clock's hour is still bold! I had high hopes that I could make use of the latest & greatest without flashing the old 4.1 Clock back in... and I hope you can tell me what I'm doing wrong. And please tell me what exactly the Magic Clock UI controls!
I so loathe that thick hour that I will go to such lengths to be rid of it.
