Yep. I have tried several. 2 gave me bootloops, so make sure you have a few on hand so you can go back and flash another if you have problems.
yes, once the playstore finishes, the response returns to normalDoes anyone else's G-Nexus basically become bogged down and unusable when updating apps from the Play store? I have had this issue for some time now, and it can happen with a single updated app even (as opposed to updating multiples at once). I just assumed this was common, but i figured I'd finally ask the question. Running jbsourcery 5.0 btw. Thanks.
None that I am aware ofIs there an option to disable the screen from coming on when I get a notification? It turns on from any app that gives a notification.
Just loaded this last night. Love it so far, but my swipe keyboard is not working. The gesture line shows up, but no words get typed. Everything in settings,language and input seems right (enable gesture typing options all checked). Any thoughts?
If I have to reload, can I just reload the stock messaging app? Where can I get that? Does the android keyboard need to be reloaded?
Kinda lost without my swipe. All thoughts appreciated.
