The swipe keyboard that I have that's not working is the stock one. Can't understand what happened - it worked fine before I upgraded to 5.0. Bad GAAPS, perhaps?The default keyboard has swipe now too. Try it out!
My only issue with the default keyboard is that I hit "B" instead of space a lot for some reason.
Should I reflash the GAAPS again, or is there a way to just flash the Messaging app?I have loaded all 4 gapps packages and the stock keyboard is swyping for me. I don't have any other keyboards installed and restore nothing with tibu
I don't think it's ROM-related. I think this stuff is Android 4.2.2-related. And I hope Google fixes it SOON...
EDIT: I just nandroided back up to JBSourcery 5.0 from 4.6 (where Bluetooth was, for the most part, usable) and my Bluetooth is shot. Completely. It disconnects more than it connects. Something in this Android release is messing up Bluetooth but NOT for everybody: just certain devices are affected.
Bizarre, I tell ya![]()
with inverted gapps, that seems to be the nature of the beast... if oyu can find any other inverted facebook would be happy to put it in the gappsI use Smart Keyboard...only one I have found that lets me resize the key large enough for me to type on
I like the inverted GAPPS, but I have noticed on like Facebook when I go to try and see who has "liked" something I can't read it because the text is dark and the background is dark. So, it is dark on dark and can't read it. Is there any kind of a fix for this or is that just how it is? If not one, then I must switch back to regular GAPPS...not being able to read a lot of stuff is annoying.
yep :/
currently charging up the phone so i can try reflashing the rom
EDIT: wiping and flashing rom did not yield any results. When i try to make any call, I get the error "mobile network not available". I don't have any bars at all.
EDIT2: Flashed back to stock without any results. Going to try a different sim card tomorrow.
Well, I tried everything (reflash keyboard, reflash GAAPS) and the swipe feature STILL does not work. Bailed on it and went to a freebie swiper I found on Play. Still think there is something wrong with the GAAPS package I used (standard with stock camera from DHO) because other people are reporting the same problem (along with having two cameras and galleries loaded, but I digress...).I have loaded all 4 gapps packages and the stock keyboard is swyping for me. I don't have any other keyboards installed and restore nothing with tibu
When you say flashed back to stock are you saying you had a nandroid of a stock setup and you went back to that? Or are you saying you flashed your partitions using fastboot or a toolkit? If the latter, which version of stock did you revert to?
I can't think of any apps I've added anything between ROM flashes that might be conflicting with it, but I'll double check. Any suggestions regarding what to look for? Thanks!Would agree. Working for most people so would assume you have an app that is conflicting with it...
