clemson77on
Member
Okay, thanks. I wasn't sure if it was the same issue or not. I didn't mean to rub it in because I absolutely love this ROM.
Good morning and it's another wonderful week with JBSourcery 5! This has to be the zenith of JB development... I'm not sure how many other little surprises you could possibly throw into it!
I know that refinements to AOSP will likely be few and far between with us this close to Key Lime Pie release. You developers are miracle workers... You've taken the best of Android and made it better!
I don't know what you have in store next, but I can hardly wait to see it![]()
How much do they pay you for this ?![]()
I'm having some BT issues as well. Everything works fine in my car, but when I tried to use BT headphones I started seeing the following issue.
I was connected to my work network via WiFi and I connected to my Motorola BT headphones before I went on a lunch walk. I started playing music through Pandora. Everything was working fine and I walked out of the office with my phone in my pocket, music playing... all good until I got out of range of the company WiFi. When the network switched to 4g, my headphones would only play if my phone was in my hand, about 1-2 feet from the headphones. If I put my phone in my pant pocket, it would disconnect. Take the phone out of my pocket, it would connect and play fine. Put it back in my pocket - disconnect.
I don't know why it worked fine on WiFi...
I also get random BT errors on screen when BT is on and not connected to anything. I'll have to remember the exact wording next time I see it. Not sure if related.
I'm on 5.0 after a complete wipe, clean install.
Only other issue I've seen is the default browser will randomly FC while viewing a page... happened twice this morning.
Other than that, everything else is running fine! Loving the ROM.
anyone else getting reboots on v5 while trying to text?
That's good to know. I downloaded then this am. Haven't installed yet. May hold off for a day or so
I guess everyone here is waiting for the 4.2.2 radios to be extracted and put into JBSourcery. I suppose I'll flash them when that happens, but other members are reporting less than dramatic results...
Whats special about the new radios? Mine are working fine.
reboots.. yes there seems to be an issue.
its something due to the merge of 4.2.2
its so hard to narrow don since its not steady and having problems at various times i have seen it once.
i am changing some thigns to see if i can track it down with an experimental build.
these are soft reboots not seeing system ui crashes just the soft reboots ive seen reported.
so we are looking at it.
and chief ..i know im late but 1 more push about how god the rom is ill get you that check i promise![]()
5.1 out on IRC!!!
Does this have the new radio's or should I flash those on top?
5.1 out on IRC!!!
