droidobsessed
In the experimental I have noticed I can set wallpaper in the pull down area but the animated pull down won't install. Anyone else with this or suggestions? I have not had any issues with this before.
I have YET to have an issue with TWRP. If I am doing a clean flash, I always use Superwipe, which formats the four main partitions. I don't rely on the recovery to do it. Highly recommended.
In the pulldown wallpaper... Clock on the 3 dots at the top and choose reset to stock. Then you can sty an animated one
I believe Team Sourcery released a Galaxy Nexus Superwipe in IRC... you'll have to ask the dev team if they can leave it up in IRC![]()
I have upgraded to 5.1 and have an interesting problem. I have used Smart Keyboard Pro for a long time and it has worked perfect on all versions of JBS so far, but not on 5.1. When I go to "language and input" it shows Smart Keyboard Pro. I put check beside Smart Keyboard Pro and then click on "default" above that and the only keyboard listed is English (US) Android Keyboard (AOSP). Usually, below that I would see Smart Keyboard and there would be a select button out to the right of it to select that keyboard, but it is not there. The only thing below the default keyboard is "set up input methods". Selecting that gives me a screen with three selections: Android Keyboard (AOSP), Google Voice Typing, and Smart Keyboard Pro. I select Smart Keyboard Pro here and then back out of that screen to the original screen and now Smart Keyboard Pro is unselected.
No matter what I do, I cannot get the ROM to change to Smart Keyboard Pro. Is there something in the ROM that is forcing it to stay with the default keyboard?
I had the exact problem enabling Swype after 2 clean installs. I grabbed 5.1.3 from irc and problem is gone, can now use Swype again. I thought it might have been an update on swypes end cuz I grabbed the newest version, but swift key wouldn't work either. Weird but fixed.
Awesome freaking Rom, I don't even want to play with anything else...thank you, devs!!!
Still "experimental" but a great release nonetheless![]()
UPDATE: I think CWM doesn't work well with TWRP. I told CWM to use TWRP and tried to create a backup, failed. So I went into TWRP and tried, failed. I then went into Goomanager and reinstalled TWRP and it's backing up now. SO, just FYI.
nope..... never recommend a dirty flash accept when reloading the same rom and version
You are correct. Sorry for the confusion!I am going to go out on a limb and state that where you mentioned "CWM" in your post above, you meant to say "Rom Manager"? Just for the readers.
And I'd love the Superwipe ZIP if anyone has it!
