Thank you for your hard work, Eagle and crew... the Deskclock now changes to any color we desire! Another Sourcery exclusive!![]()
5.1.3 is great, but what happened to the notification widget? Loved that thing!
I know this is only part of what you wrote, but it summed up my feelings on this whole Sourcery-bashing thing. The devs work really hard providing us with a quality product, and never once have I heard therm ask for anything but a little respect for their efforts. Hats off to you and your ROM! Thanks to your work, I now have a phone that I love and am proud to hold up against any other!Thank you for your hard work, Eagle and crew...![]()
I look forward to all ther improvements you'll make in the future, and know you'll get Key Lime Pie to us faster than anyone, with a host of extra goodies I can't get anywhere else.
BTW, no fanboi here. I am a non-paid spokesperson. Just an average schmo who loves this ROM!
Can my lazy butt do a dirty install from 5.1.3?5.1.5 super goodness!!!![]()
Me too! I did it and I'm rocking 5.1.5 quite nicely thank you
Haven't found any new stuff yet but it seems very snappy. Another great update to a great ROM!
Is IRC the only place to get experimental builds? I checked the website and the built-in ROM tools, but nothing.
4.4, i think it was, had inverted pandora with no ads and unlimited skip.... can i get that for 5.1? that shit was great...![]()
I downloaded Pandora but it won't install. Tips? I know it's probably something silly I am not doing.
When try to copy it as system app that fails
Did you set permissions when u copied it over?
Thanks! I'm downloading v5.1.5 right now to see how it goes.
Site note, and not really related to this ROM, but anyone have issues backing up ROMs via TWRP? I've tried a couple times with no luck. Says it can't write to the backup folder.
UPDATE: I think CWM doesn't work well with TWRP. I told CWM to use TWRP and tried to create a backup, failed. So I went into TWRP and tried, failed. I then went into Goomanager and reinstalled TWRP and it's backing up now. SO, just FYI.
Don't install it. Copy it to system/app and reboot
+1I know others have reported issues with TWRP but I have not experienced any issues backing up or with it wiping.
For whatever reason I can not get this to work. I will try again when JBS gets another update. Thanks.
