Can I dirty flash from version 2.0?
Thank you too, Viper. I was really pooping a brick there... No pun intended. It is one thing to mess up your own phone; it is another to screw up someone else's.
No, we have modified alot since 2.0. I would assume you will have issues doing a dirty flash.
anyone know how to get the f'ing led to work? i cant get it right with neither built in or lightflow. with lightflow it either flashes once then dies or not at all and with built in it flashes constantly even after notification is cleared....WTFFFFFFFFFFFFFFFFF..!!!!!!!!!!
oh and whats a good kernel, im using franco right now gonna see how the temps run...
What inverted gapps are the best?
Over on xda developers, there is justinbeans all in one gapps. I use it and it works with 2.2
Only thing is you gotta switch out the contacts.apk and use the sourcery roms' contacts.apk from the sourcery zip
Okay folks, looks like I've found an "issue" with 2.2:
When I am on my A2DP Bluetooth headset, I should be able to press the call button and get a "Speak Now" prompt to voice dial. But on JBSourcery 2.2, I get this:
"Speak Now. Goodbye." Immediately. I have no opportunity to voice dial at all.
This HAS to be a 2.2 issue because it worked on 2.0 and I clean flashed this ROM. I would appreciate validation if someone can duplicate the problem, and identify a potential fix. I may have to nandroid back to 2.0 because I use this feature a lot![]()
I just clicked on the voice icon from the google now... told it to call Terri.. and it showed Terri and her number... and dialed it..
