New lean 4.5 is running pretty good so far for me
Oh no... that pesky Bluetooth problem is back...
I flashed 3.1, and then flashed Lean 4.5.0. I turned on my BT headset, hit play and NOTHING. That initial Play command from the headset fails again!
Okay, says I, it's the kernel. So I re-flashed the ROM and Gapps, opting to leave the stock Trinity kernel running.
Same thing!
Now I'm torn: do I keep the upgrades of 3.1 (even though they really don't apply to me) and lose my BT functionality? Or nandroid back to 3.0 and enjoy my BT again?
And can the developers look to see if ANYTHING was change in the BT coding?
Thanks!
can you try re-pairing? nothing changed in the BT/kernel areas
Okay, I unpaired the headset and turned it off. Then turned it on and paired it. The problem persists, I will try a whole different kernel to see if I can isolate the issue. Hold on...
EDIT: Okay, in deference to the developers, as soon as my phone is charged back up I will wipe everything and clean flash 3.1, opting to NOT restore any BT access points that are backed up. And we'll see if that works. I sure hope so![]()
