Ok it's installing as we speak. How do I back up contacts and wifi passwords? I think that'll be the last thing to do before I can flash the new rom![]()
I'm doubtful of my wifi passwords carrying over since I have never as far as I know done syncing with google before so I'm not sure if that's setup like it should be right now.
Also, I only take from the backup the apps that came from the playstore right? not even other regular preinstalled ones like camera for ex?
Oh wait it looks like my contacts and my wifi points have both been backed up according to titanium backup...I'm gonna attempt to flash it now from recovery after I do the 3 different resets that you said.
sounds good...i am using the backup assistant plus from the settings (that's what i assume you meant) to back up the settings and stuff...it's being slow as heck but hopefully it will hurry up and i will try to flash
Oh alright...well in that case i'm sure what you meant and shouldn't I be guranteed safe for the contacts since i have them on card?
Oh, yeah I found that menu you meant! and turns out i already had that checked, and it's already syncing to my gmail so I guess i'm good on that one
just got to recovery, i only see 2 options for resets, not 3. there is "wipe data/factory" reset and "wipe cache partition"
EDIT: Just a thought, I downloaded the CleanRom into downloads on the phone itself...won't this be lost after i factory wipe everything? or will it still be there in recovery?
I did all resets, now how do i find the ROM to flash to?
Ah yes you are right I found it and now I'm going through setup. It is asking me for which launcher I want...I'm assuming there will be a way to change this later...I am using nova right now but i'm gonna go with Touchwiz and see what happens lol
