here is the fix...First unistall your current TWC apk>> goto the marker and install ES FILE EXPLORER >>go into ESFE setting and ALLOW ROOT CHANGES,then go to root folder/system and rename Superuser.apk to SU.apk... now redownload TWC app from the market and login it should work now. ***NOTE renaming the Superuser apk name DOESNT change root access or unroot your phone :dancing2:
Nope... Didn't work. Initially I was using the hacked twc app bit that now says I need to update. I uninstalled it... Renamed supersu.apk to Su.apk and installed Tec from market and it runs but will not play live tv.
Nope... Didn't work. Initially I was using the hacked twc app bit that now says I need to update. I uninstalled it... Renamed supersu.apk to Su.apk and installed Twc from market and it runs but will not play live tv.
Can you go into some detail on what and where you did?It was editing the build prop and taking out the test-keys that did the trick. Once that is done the regular market app works.
