GalaxyNexus
Does anybody know how to do this? I turned off my phone at night and in the morning I got stuck in a random reboot. Now I'm wanna unroot my phone. Unfortunately I can't seem to turn on USB debugging.
Does anybody know how to do this? I turned off my phone at night and in the morning I got stuck in a random reboot. Now I'm wanna unroot my phone. Unfortunately I can't seem to turn on USB debugging.![]()
USB debugging is turned on in ClockworkMod [i.e., in the default.prop file in the ramdisk] (you can use that to your advantage to run adb while booted in custom recovery).
What makes you think that it isn't enabled?
I did the Wug-something easy method root... Not adb or sdk. Sorry, I don't really understand your terminology: prop file? Ram disk? I'm not sure what your talking about the USB being on in recovery mode because my computer doesn't recognize it. Sorry.
No worries. I was just trying to point-out that USB debugging is already turned on in custom recovery mode (not stock recovery, though).
I don't know if the Wugfresh toolkit installs both adb and fastboot drivers for you, but I'm guessing that might be your issue.
Check out this post for help with installing the adb and fastboot drivers:
How to install the adb & fastboot USB drivers (MS/Windows users only)
Cheers!
Scary Aliens toolkit can probably help you, right SA? Check his sigline for a link.
.Did you ever make a backup in recovery (or with rom manager)? If you could restore to stability, it'd probably be easier to unroot with a toolkit. Otherwise, you're looking at fastboot most likely.
). I turn off my phone before going in. After the movie I try to turn my phone on and after the first pony thing my phone freezes up and then continues trying to turn on. Keeping my calm I took out the battery and tried to flash a backup. The same thing happened (except w/ stock android boot animation).
. VZW totally flubbed and gave her a refurb, but I'm pretty sure there was just an issue with the battery "sense" file thinking that the battery was depleted, even though it wasn't really. Can you try wiping the battery stats? I think there's an option for that in CWM.Thanks, much easier to help when we have more info.
Can you wipe caches and reflash AOPK? (or flash anything?)
Then if you can get it running, you can try renaming a backup, if needed. My keyboard likes to add a space after every typed period.
Deleted everything, cache, battery stats, and did a factory reset. Flashed aokp b28 and it did the pony thing about 4 times before it started over.
Thanks 4 the help guys. I installed adb and sdk but I can't get anything to work if I can't find my phone so I don't know what to do.![]()
Format system, data, cache, dalvik cache, then flash your rom.
I was stuck on the Google screen going from liquid to aopk until I also flashed system.
GalaxyNexus,
Have you tried restoring a known, good Nandroid backup?
That's your best, first thing to try...
Also, for the other ROMs you are flashing, did you double-check the MD5 sums on them to make sure the downloads are good?
Where's the option to format dalvic cache? I found everything but that.
Yes, I have. I had been using M4 for a good couple weeks with no problems until I encountered this mess up.
[it should].Yeah, that's a little worriesome that a Nandroid restoration wouldn't fix you up...[it should].
Wait, is a Nandroid the same thing as a normal backup? Sorry bout the stupid question.
You make a Nandroid backup in custom recovery (ClockworkMod) under "Backup/Restore"...does that ring a bell?
