.... so then flashed Basil's dark viper - so i now have a mixture of 2 full themes and 2 different status bar themes on top!
.... but i finally like the result
Here is an example where the trusty nandroid backup just prior to flashing a mod is a clutch move. If stuff gets borked, restore nandroid and keep on rockin.
Make nandroids a habit, or you'll lose stuff you don't want to lose eventually.![]()
Dan: does Venom Hub options show up under Basil's Dark? Everything is whited out for me.
Some options might be available only via license/donation:
https://play.google.com/store/apps/developer?id=Team Venom - ViperOne&hl=en
If you should choose one of the above listed,some are for the M7,the others for the M8.
