Root [Virgin Mobile] [BETA] [4.4.4] Cyanogenmod 11 Unofficial
Which recovery is best to flash this rom? I've tried cwmt 6.0.4.8 and it says it installed fine but I rebooted my phone and it was stuck at the LG screen for 15 mins.
Just wanted to say thanks for this rom. getting good battery life now and seems really stable . i used set cpu to set up some profiles and all is great keep up the great work
With heavy usage
Is anyone having phone call issues? I've noticed the phone call audio cuts in and out on my phone. Or just doesn't output any audio at all.
It says calls are working but when I attempt to make a call the screen stays black until I press home and when I switch back to the dialer app I can't press anything, I have to hang up from the notification and I can't get the dial pad to show.
That's actually android itself... To fix that, go to: Settings -> Wifi -> Menu -> Advanced -> Keep Wi-Fi on during sleep and select Only when plugged in
I need wifi while phone is sleeping because i use a wifi calling app. Good to know tho thank you.
I have too, it might be that the rom isn't controlling QDSP input/output levels correctly (as the audio codec is the SoC's DSP itself)...
I also got this state, since a long time do not remember what I used, I believe that is one of the libs just, maybe we caught the stock rom Some of it should work. If the wrong is likely to give brick
There is a few things missing from the kernel still. I'm going focus on that and see if I can come up with anything.
It might help to pull the kernel configuration from liquid smooth and compare it, to see if there's anything missing or different related to the camera libs
hey guys could help me? I know that is not the area nor the right post to ask, but recently my lg optimus of nowhere f3 gave brick, and when I try to flash a stock rom the KDZ of the following error:
[R&D Test Tools Log File]
18:34:07 : Start fn_StartUpgrade
18:34:07 : Extract kdz file
18:34:51 : kdz decrypt Success
18:35:25 : Extract file Success.
18:35:25 : LGMobileDL Load.
18:35:25 : Port = -1
18:35:25 : Connection check start.
18:35:40 : Check Phone mode = 2
18:35:40 : Phone type check.......
18:35:41 : LGMobileDL.DLL Loading....
18:35:41 : _SetAuthMark Fail
18:35:42 : _SetAuthMark Ok : wAuthMark(65535)
18:35:42 : _DetachDLL Call
18:35:47 : _DetachDLL Call End
18:35:47 : Param : Path = C:\ProgramData\LGMOBILEAX\Phone\P655H10B_Develop.wdb
18:35:47 : Param : moduleDir =
18:35:47 : Param : waitTime = 25496712
18:35:47 : Param : UsbHighSpeed = 1
18:35:47 : Param : PhoneMode = 2
18:35:47 : Param : BinVersion = P655H10B_vivo
18:35:47 : Param : AuthMark = 65535
18:35:47 : Call fn_StartUpgrade
18:38:57 : 3GQCT : wParam = 100, lParam = 0
18:38:57 : Step : Upgrade Error error code = 0
18:38:57 : ResetStartInfo() Call
18:38:57 : _DetachDLL Call
18:39:02 : _DetachDLL Call End
18:39:02 : FreeLibrary Call
18:39:02 : FreeLibrary Call End
18:39:02 : ResetStartInfo() Call End
18:39:02 : 3GQCT : wParam = 100, lParam = 64
18:39:02 : Step : Upgrade Error error code = 64
18:39:02 : Finish All test
have access to cwm, already I tried installing a custom ROM, but the error in the mounting system, this taking to enter the cwm,
the error of cwm: mounting / cache /
mounting / data /
and mounting / system
already tried to do hardreset and install a custom rom, but is locked in the boot screen, I insert an attachment here the log LGMObilesupporttool, tried to use two laptops and nothing, tried reinstalling drivers and msxml and nothing.
mounting / data /
No clue, sounds like the sprint/virgin mobile firmware will not work on your phone. Take it back to get it fixed.
