JupiterOne
This post has been removed for legal reasons. Sorry folks!
Thanks. I feel i may have gotten a golden chip in mine as it runs great at 1.9. Graphics seem smoother at 1.7 hmm.Good work! 1.9 huh? That's pretty impressive. On my previous phones I've noticed some could go higher than others so maybe not everyone can run that high.
Pretty impressive list of governors too.![]()
I may have added that last night!So does smartassv2. Is this the same kernel I tried, or is it updated?
Now that i look at my files, the one you got was the last one.Smartassv2 is in the version I'm using. I'm just wondering if you updated the kernel since I tested it?
Sounds like you have a memory space issue. That happened to me once to. Your gonna have to clear some space because the file needs to be uncompressed during installation. Sorry to hear your having problems.arg it wont flash. i keep getting an error. just says error flashing zip then your file. the file is on the ext sd removable card not internal. i also have low memory on the sd card due to partioning and using link to sd. i also have low internal memory after backing up. someone help! im also doing all this from my phone and not an outside program if that helps.
Believe me I totally understand. I just recently got into kernel building myself and there's a lot more complications/legalities than with ROM editing.
As you are probably aware, Android runs the Linux kernel, and Linux is licensed under the GPL. If you check out that legal document, when you modify kernel source and distribute the kernel publicly you must also provide the source to that kernel.
This is the reason Samsung legally has to post kernel source, and it follows that kernel devs must do it as well if they modify that source.
I'm sure we can get someone to help you jump through the legal hoops if you aren't sure how.
Not trying to stifle development or anything like that, but like I said its a legal requirement for kernels.
Anyone wanna pick this project back up? Its not hard to do what he did.
U gonna add Lower voltages? Battery could really use it.
Would you happen to know where I can look to UNDERclock the GPU?
Looks like it does indeed work (to some extent at least). I did two Antutu runs, one with max GPU set to 400, the other set to 200. As you can see from the 2d graphics results, there definitely was a difference!the gpu clocking works? (sticks?)
