JupiterOne
I'm new to this and made this for myself and being myself i make backups and i do not mind sharing. You use at your own risk. You DO know this can break your precious little device but you can't resist. You know you MUST backup your precious little device but but but... And here we are. It is YOUR choice!
What we have here is a Virgin Mobile Samsung Galaxy Victory 4G LTE JB 4.1.2 kernel with disabled speed governor of 1.2Ghz. What you get is 1.5Ghz. I compiled this from the samsung source SPH-L300_NA_JB_Opensource. There is also a SPH-L300_VMU_JB_Opensource in the repo but it scored lower on Antutu... 'i know it means nothing but whatever'
http://planetjupiter.com/android/share/antutu-na.png
http://planetjupiter.com/android/share/antutu-vmu.png
So assuming your phone is rooted and YOU have decided to try this...
This is a zipped boot.img. I used [OUDHS] TWRP 2.4.3.0 For the Galaxy Victory to flash it. Just copy this to your phone, preferably your extSdCard. Boot into TWRP 'recovery mode' by turning your phone off then, hold up volume and power till you see 'Recovery booting' show up in the top left corner and let go of the buttons. Once your in recovery mode you will want to clear your Dalvik cache so touch 'Wipe --> Dalvik Cache'. I don't see any need to clear 'cache' as 'under my understanding' clearing Dalvik cache will cause all the needed stuff to rebuild after reboot. So any way. Once that is done, touch the return button to main screen and touch Install. Now point to where you stored the kernel and once selected swipe install, once done, reboot to system. When you reboot all the components that were cleared from your Dalvik cache will be rebuilt so don't go freaking out. Just give it time to rebuild and once it finishes booting your done. You can open settings and scroll down to 'About Android' and see the kernel version has changed. You can also check cpu speed with a android info app. I use Android System Info. I'm not noticing any power use difference but i am noticing it is snappier. Much better response. If anyone has any suggestions on some kernel settings to try or need let me know. While sniffing around the kernel i saw lot's of 'stuff' that can be turned off that i would never use 'tv remote driver, force feedback steering wheel driver and tons more. I am happy to make changes within reason and functionality so don't be scared to make suggestion.
Now i warned you i'm new to this but that, this kernel works on MY phone. If you made it this far and your phone is now broke, tuff. Yea really. See the thing is i stated up front that i made this for me. I mentioned this could brake your precious little device. I also mentioned backups and i bet by now half of you are hoping you had taken my advice and the other half are cursing my mother. That's all fine see, cause your problem is not mine.
I'm Jupiter and this is my RedSpot...
RedSpot_VM_SPH-L300_v.04
RedSpot_VM_SPH-L300_v.01
