Hmmm, did you use any of the fixes? What recovery mod?
I have philz touch recovery, and i started off with the nightly posted here but then i dirty flashed the newer nightly to fix a camera issue (12/15/13) which can be found in Struckn's CM 10.2/CM 11 thread along with flashing the dalvik patch from that same thread, and thats pretty much it other than flashing a dkp kernel for overclocking
*For safe measure I did wipe the dalvik cache AND wiped the cache before flashing the above but i did not do the factory reset/delete data* but i don't know if that makes a difference, I am still learning
