richking34
The ROM is stable for a nightly?
Just make it part of your Power menu.
No option on my power off menu. How to enable screen shot on the menu? Do I need to down load the app from play store?
Thanks.
Does anyone know how to do screen shots in 4.4.2? Thanks.
MMS and calling is working great, just tested it![]()
I still can see my whole internal storage.
Just 0. And all my previous stuff all at same top level as 0.
I'm having several issues with this ROM....one...if I switch off WiFi...I have to reboot to get mobile data.... If I flash mopedryder APN fix WiFi no longer works at all.... MMS doesnt send on lte or 3g... When working lte and 3g are fine....
Did you try wiping the Dalvik cache? I had similar issues until I wiped. I am currently running the latest version with no issues. I don't use MMS so that is the only thing I am not sure on. Also I thought this ROM already had the APN fix applied?
No its working fine on lte and 3g![]()
I can't mms working eitherLauncher
Have you tried sending an MMS through the stock messaging app rather than Hangouts? I was under the impression that Hangouts cannot handle MMS but I could be wrong.I've tried everything I can think of, and cannot get MMS to send (using hangouts strictly).
Went from Philz to CWM 6045, used the posted links for 20131213 and gapps, tried apn fixes (even though it's supposed to be included). Wiped Cache, Dalvik Cache, System, Data each time.
Those who have it working, could you explain if I'm missing something.
You have mms working on LTE?
I sure do, i grabbed my mothers at&t note and tested the messaging right before i posted here
I must be lucky or something lol
