ebildude123
Member
Posted patched dec 21 nightly!
I installed all the files on this OP ..booted up perfect ..LTE works but only problem with me is mms is not sending/receiving even when im og 3g..how do I get mms to work?
Wipe dalvick n partition .... Then apply moperider patch 2... Then dirty flash ROM., then apply modem patch.....
Happy holidays everyone!
I have updated it to the 12/25 nightly.
wipe cache and dalvik cache then install the new version and you should be fine.... Just spent the last hour setting up the 12/21 nightly
But thank you so much for all your hard work!
Is there a way for me to patch over the 21st nightly, and keep all my settings? Or should I factory reset, wipe dalvik and cache? Then install rom and gapps, then restore with Titanium?
Just curious if there's a way of making sure my last hour wasn't in vain hahaha
However, I'm unable to restore some backups I made in Titanium
Are you restoring "App only" or "App plus data" in Titanium? Data for TW versus AOSP is not always compatible. For example, you can restore S-Voice for use on AOSP ROM's, but only if you restore "App only."
Yeah. I just realized that now. I'm trying to figure out now how to get the app back because whenever I try to install from the Play Store, I keep getting an Unknown -24 error.
EDIT: Alright. So I fixed the error. Just had to delete a folder from data/data/com....
Also, when I was on TW I made a backup of Dialer Storage so I could restore my text messages and such. However when I restore and reboot, I get a continuous
Phone has stopped working" error. I have a feeling this has to do with the TW vs. AOSP you mentioned earlier. Any solutions of how I can successfully restore?
i have no sms after flashing, it worked for about 10 mins, i restarted now i have no smsThis assumes you already have a custom recovery.
You need CWM 6.0.4.3+
Flashable zip to upgrade your recovery to CWM 6.0.4.5: http://itslightness.com/d2vmu/CWM6.0.4.5.zip
New! ROM download: Dev-Host - cm-11-20131225-NIGHTLY-d2vmu.zip - The Ultimate Free File Hosting / File Sharing Service
Release Notes (12/25):
Added APN fix
Removed assert lines
Removed duplicate ringtones & notification audio files
Added AppOpsX - native App Opps not working (removed access in 4.4.2). Hit install App Ops X in the app if you plan to use it.
Thread changelog:
(12/25) Posted Dec 25 Nightly
(12/21) Posted Dec 21 Nightly
(12/13) Changed GAPPS link
(12/13) Posted Dec 13 Nightly
(12/10) Posted Dec 10 Nightly
(12/10) Posted CWM 6.0.4.5
(12/09) Posted Dec 08 Nightly
(12/09) Posted CWM 6.0.4.3
Credits:
CyanogenMod team
Moped_Ryder (APN fix)
Remember to factory reset before flashing!
KitKat gapps: http://www.invisiblek.org/gapps/gapps-kk-20131208.zip
old & obsolete download links:
Dev-Host - cm-11-20131221-NIGHTLY-d2vmu.zip - The Ultimate Free File Hosting / File Sharing Service
Dev-Host - cm-11-20131213-NIGHTLY-d2vmu.zip - The Ultimate Free File Hosting / File Sharing Service
http://itslightness.com/d2vmu/cm-11-20131210-NIGHTLY-d2vmu.zip
http://itslightness.com/d2vmu/CWM-6.0.4.3-d2vmu.zip
http://itslightness.com/d2vmu/cm-11-20131208-NIGHTLY-d2vmu.zip
Anyone know of any way to disable the lock screen animation?
Are you referring to the CRT screen off animation?
Yessir. I ended up downloading Gravity Box and changing it to Fade lol. But if you had another solution, that'd be welcomed.
Since I already have XBlast installed I just used their option to change it to fade they have other options as well. Just make sure to reboot after you select your option. I HIGHLY recommend XBlast to everyone to try out.
Pic of options:![]()
Two huge thumbs up for Xposed Installer in general and XBlast Tools specifically!!!!!
