noxiousfix
I recently rooted my ls720 with motochopper and all was working great until I found my 3 year old with my phone. Uninstall Master was open on the System Apps tab - not good. Ever since, Play Store and most other Google apps won't open. I get this error: [HIGH]google.process.gapps has stopped unexpectedly[/HIGH]I have NO IDEA what he deleted so I figured I would just replace the stock firmware and take all back to zero...
And therein lies the problem: following a "guide" I found in this forum I began the process.
Found the right .cab file. check.
Converted it to a .kdz file. check.
Connected my phone to my pc with the right drivers. check.
Load the newly converted .kdz file. -FAIL-.
For whatever reason, I get this error: [HIGH]Launching S/W update
Unpacking KDZ
kdz decrypt error.
Extract file error
===FINISHED===[/HIGH]So, is there anyway to replace stock with the original .cab file?
OR
Does anyone here have a verified LS720 kdz file that I may use to fix my phone? Technically, it's not bricked. I can make and receive calls and use most apps but I can't add new apps and that really sucks donkey dong.
Any help would be greatly appreciated!
Unpacking KDZ
kdz decrypt error.
Extract file error
OR
