Yes any form of "reboot recovery" will result in a factory reset for the vm-f3. This is a product of our bootloader being locked. It's a long and technical store.About never using "Recovery Option", what is that to be exact ? Would #adb reboot recovery result a factory reset ?
Excellent job figuring out the problem guys. If you have any other issues let me know.
Ok, wanted to update after I've had more time to play with it. The files are successfully copying to the correct spot, but I still can't get it to boot into recovery mode. Starting to frustrate me as I repeat every step right before I go to reboot and nothing.
Just saw your edit...Ok, finally got it to boot into recovery mode. Chose to backup on /external_sd
Then it says:
Backing up recovery image...
Backup of recovery image completed.
Backing up system...
Error while making a backup image of /system!
Tried a couple different SD cards thinking that was the issue, but same thing.
Edit: Finally got it to backup. Took a couple restarts, but it finally got copied. Now to try to and reformat it and reset everything on it and see how that goes.
Glad to hear you got it working.
The vol down did the trick, thanks! My first time using the touch version of CWM, very easy to navigate, almost too easy as it doesn't require having to scroll the to the 'yes' to confirm an action. Thanks again, the instructions worked like a charm.You need to hold the volume button in the down position plus the power button to enter recovery.
Good to hear, glad I could help.The vol down did the trick, thanks! My first time using the touch version of CWM, very easy to navigate, almost too easy as it doesn't require having to scroll the to the 'yes' to confirm an action. Thanks again, the instructions worked like a charm.
No UICC won't help. Your previous post sounds promising. Yes, you might have released the buttons to soon. Keep me update, LW.Would the UICC unlock be helpful in my situation?
I never officially tested it with Boost but I believe other Boost owners are using it with out issues.Will this work on Boost Mobile Optimus F3?
Since my install of the VM version of CWMT, nothing happens. If the charger is plugged in, the phone goes right to the battery display; if the phone is not on the charger, it simply reboots - without going into factory reset.
Sent from a Boost Mobile LG-LS720 using Forum Runner
Your's is a special case, LW. Your not able to write to any partition on your device as you've told me many times. The stock recovery probably became corrupt during the flash/install of the custom recovery. A device with no working recovery installed would just boot back to the system.
So, I'd have to get another stock ROM from LG? Would that do the trick... just start from v7, ground zero? Gosh, I hope so... LW
I hate to say it but that wouldn't work either. Even if you could get LG to send you a copy of the stock rom (which they won't). You would still need a way get it on to your device. Once again, your not able to gain r/w permission to the system, data, cache, etc., nor are you able to use the Flash Tool or recovery.
I wish I know what was going on with that phone of yours, LW. I also wish I had an easy fix...sadly that's not the case.
gherkaul, what about a Windows install of TWRP? I installed CWM's version of Superuser, and the phone now boots up without the "Android Is Upgrading" prompt while all apps get 'optimized'. Also, if you know anyone that has further knowledge, I'd appreciate any assistance at this point (and, thank you for all you've done to help). I had great luck with TWRP when my HTC 3VO was working (sadly, it got dropped into a hot tub when someone was taking pictures)... I appreciate anything you can do. Maybe even a walk-through with Flash Tool, to rule out something I'm doing wrong. Cedric Counotte (of 3C) recommended motochopper. Sheesh, I followed sammyz's directions to the letter... maybe if I copy all of the data off of my SansDisk Class 10 32 gB micro SD, and re-format it to this phone... well, sound off when you've got some time, and thanks - LW
