TWRP Touch Recovery Bumped!
TWRP for the Virgin Mobile / Sprint LG Optimus F3
If you are on a T-Mobile / Metro PCS LG Optimus F3, Go here. or here
TWRP = Team Win Recovery Project
* TWRP Version 2.8.0.0
*Works with Virgin Mobile Optimus F3
Has not been tested on other variants.
Source: TeamWin - Home | TeamWin
Visit: TeamWin Projects - TWRP 2.8 - | TeamWin for details
What doesn't work:
Haptic Feedback
You tell me?
Data Partition restore has been fixed by gherkaul
Thank you
Warning KERNEL PANIC:
Do not reboot into TWRP with 'adb reboot recovery' or reboot into TWRP while inside of TWRP. Doing so will wipe your /data partition.
Always boot into TWRP using the button combo.
CWM vs TWRP:
The Interface:
I think everyone might agree on this, clockworkmod isn’t the best looking recovery out there. TWRP has an option to turn the display off after a specified amount of time. CWM does not. Confirming things and unlocking the screen requires a swipe gesture. CWM on the other hand, confirming things require you to swim across waves of “No” to find and select the “Yes” option.
Backing Up and Restoring backups:
The backup option in clockworkmod directly starts the backing up procedure, doing the same thing in TWRP presents you with some nice options, allowing you to control which partition you want to backup, in which storage you want the backup to be and also, if you want compression to be enabled or not..
There is an advanced restore option available in clockworkmod recovery, allowing you to restore only one partition of your choice. TWRP recovery bests clockworkmod recovery in this section, by giving exactly what I asked for in the previous point. TWRP recovery also allows you to rename the backups.
Other not-so-often used options:
Clockworkmod recovery has some nice features like:
source
First time you boot into the TWRP Recovery, it may take upwards of a minute to initialize.
To Install:
*Your phone needs to be rooted
*You need to enable USB debugging in Settings > Developer options
DOWNLOAD:
https://s.basketbuild.com/devs/xclusive36/fx3/vm/stock
This link points you to multiple files, make sure you download the correct one!
The Download is for installing on Windows. Follow the readme file that's included.
To get to TWRP:
After installing, Power down your phone. Once your phone is off, Hold down the Volume Down button. While holding down the Volume down button, press and hold the Power button. When you see the screen that tells you to release all buttons to get to recovery, Let go of all of the buttons. Your phone will boot into TWRP.
Changelog:
11/17/2014
- Data Partition Restore bug has been fixed. Very stable recovery now
- Thanks gherkaul, your awesome
10/4/2014
- Added USB Mount Support
- Enabled Partition SD Card file format ext3 or ext4 (THIS WILL BRICK YOUR PHONE IF USED IMPROPERLY)
10/3/2014
- Re-Fixed recovery.fstab confict (loads quickly now)
- Removed un needed files from the ramdisk
9/19/2014 - Fixed recovery.fstab conflict
9/17/2014 - Initial release
What doesn't work:
Haptic Feedback
You tell me?
Thank you
CWM vs TWRP:
The Interface:
- Wipe Dalvik Cache
- Wipe Battery Stats
- Mount/unmount and format any partition
- Fix permissions
- Fix permissions
- ADB Sideload
- File Manager
source
To Install:
DOWNLOAD:
To get to TWRP:
Changelog:
11/17/2014
10/4/2014
10/3/2014
