I don't know. I backed it up with 2.5.0.0 so I was just wondering. I really don't know what i'm doing![]()
garwynn said:How did you dump this? dd?
Basically, if you dump each partition that you want and then label them <partition>.img I can then start working on it.
You'll need to know what mmcblkp## partition they are though to do this way.
And when you do the ROM, do 2. One stock like above, one with this just flashed right before dump:
http://garwynn.rainmotorsports.net/SuperSUBusybox.zip
Boot partition is also handy to have. The rest I'll check with another guy and see what they were able to come up with.
If it helps, I flashed the stock nandroid and did a factory reset but I can't get wi-fi or bluetooth to turn on, and it looks like the mobile data doesn't work even though it has a 3G connection. Maybe it needs more than just the /system to get the connections othre than phone calls to work
Can they also make a .tar for just the recovery? I want some OTA![]()
