Root [Virgin Mobile] [TESTERS] Lets Find Best Governor + OverClock [VaeVictus]
Which governor gives you the best performance/battery-life?
  • Total voters
    11
What scheduler should it be set to? Or does that have anything to do with the test? Right now its on cfq
We don't mess with schedulers during benches (most ppl) but that shouldn't mess with scores all that much, can u screenshot the score sheet?
This what you talking about?
You have a very slow sdcard, and either you have stuff (apps/services) running in the background taking up your cpu, or you are attempting too many benchmarks in too short a period of time. Benchmarks stress out the cpu/gpu and make them very hot. Heat causes errors, making the cpu/gpu perform the same calculations over again, lowering your score.
For high benchmark scores, keep your phone cool, let it idle for at least 5 minutes before running a benchmark, clear out the task manager, and see if there are any services you can stop, airplane mode helps as well. ;)
OK I will give this a try. I got a class 4 men card. I will clear ram and wait bout 10 mins before I try again. The phone wasn't running hot though. And I been clearing all the running apps before I test. I appreciate all your help!
FYI- class 4 is not very good. Class 10 is what you want, and you can get a 32gig class 10 on newegg for less than $20. ;)
Be sure to wait 5 minutes after clearing ram, Android doesn't necessarily free it up right away!
Ya I no it isn't very good. But I'm turning the phone off and letting it sit for a few. Then I'll try. U got a killer ROM I just can't seem to get it to work the same way everyone else can :/
Dont get hung up on the bench numbers.
If your phone runs smoothly without heating up that is all that really matters.
It does do that pretty good. Earlier I just had to try mc4 being I actually got enough room now. And it ran pretty smooth until I got a phone call.
Reflashed let it sit by air conditioner for a few to cool off. Closed all
Apps and cleared ram. And my score is 11820. Idk guys. I guess as long as it does what its suppose to do that's all that matters!
After a long nights work for this noob I finally fixed :D
Hey jerry I got a question about victorious. If I remove my SD card while the phone is on will that ruin the swap or damage it?
It can damage your card. Turn your phone off if you have it swapped. Dont unmount as that will mess up your internal card.
Please post questions about Victorious in it's thread, this thread is about the kernel, that way people can find the info you have asked about and it will help everyone. ;)
Is anyone else having problems with antutu crashing on them?
Antutu will often crash if you don't let your phone sit idle for about 5 minutes before testing (at least it can crash when using 1.8ghzCPU and 400mhzGPU). When it crashes on me, it's usually because I've been doing some testing and the CPU or GPU temp is too high (the GPU really heats up over 300mhz).
If antutu is crashing, you may be OCing too close to your cpu's max.
Might wanna back down on the speed a few notches even if it's stable during normal use, for safety's sake. Not worth stressing the cpu and potentially shortening its life.
Heat damage is cumulative, and if you're pushing your cpu over time its ability to OC can degrade. If you're barely stable at 1.8 and continue to run at that speed, you may find a year from now that you can't run 1.8 at all, and now 1.5 is barely stable; whereas if you had been at 1.5 the whole time there would have been no change.
