what version software are you running? did you already flash back to stock?
just tried to flash to v6 using your method but i get errors in the process cant tell what they are cause the updated program isnt in english just a bunch of question makrs
You need to install the LG Mobile Updater from lg's site. just choose the lg fathom or something if it asks you to select your phone. thats why you cant see anything.
Google can really be your friendI have no idea how to use a command prompt and navigate to where the sdk tools file is located or whatever. I need to get this recovery back but can't figure it out. PLEASE HELP ASAP
After flashing back to stock, I got stuck on the Android logo loop for 40+ minutes.
Step 4: Rename the cab file to VS740ZV6_01.cab (If you do not see the .cab extension DO NOT add it. Also You may not have to rename it if you downloaded it as the same name.)
Step 5: Extract the zip file's contents to this folder and connect USB cable to phone.
I keep getting an error message on the last step for flashing v6... any help please?
