death2all110
Android Expert
the windows command prompt Start>run>cmd
when i try to do the commad prompt it says that it isnt recognized as an internal or external command....wgat does that mean?
I've restored and unrooted v8 stock rom and using the method for flashing the recovery back stock towards the bottom of the post... my question is... when i boot into recovery after i have stock what should i see? i never tried recovery mode on stock so i cant tell if it worked... what i see is an android with an exclamation point
Thanks darkxsun, busy week. Damn..
Have you thought about trying my method?
http://androidforums.com/ally-all-t...nteer-who-wants-go-back-completely-stock.html![]()
You can post that to my blog if you want, and then i can merge mine and yours
Si Senor SWC2001 LolSorta like a mind meld?
I didnt know you knew how to do that.
