if the screen turns blue does that mean its bricked? :-/
go into settings, Applications, Development and make sure usb debugging is on.
got a bad copy of the tool i had that one as well and it should be in englishI'm Running Windows 7 in XPSP2 compatability and tried it several times.... Phone upgrade men shows a bunch of question marks, and i keep getting errors of various gif files not found such as "C:\ProgramData\LGMOBILAX\image\header.gif was not found." apparently the LGMobile support Tool isnt installing properly.... Any thoughts?
what does the stock recovery look like
Greetings death2all110. Yet another root idiot seeks your counsel. Similar to lacey, having misinterpreted how Titanium Backup works, I deleted a few too many things I shouldn't have.
I am also having the exact same problem when trying to flash to the v6 ROM. I was hoping you had come up with a quick solution you could share.
I'm using Windows 7 Ultimate.
Thanks
-Mael
