Ok. I'm using the charger the phone comes with and it's never showed this before. and i have the power saver set to turn on @ 30%so i don't know what's going on.
It could be the outlet or extension cord you are using. Try another plug. If it persists in all outlets the same house/building, the wiring may be f**ked up, try another house/building.
An app wouldn't do that... are you using the original cable?
