Kelita
So last night I flashed to MikG's rom. After I got everything just so, I got constant FC's on all kinds of programs after a reboot. Figuring I re-installed my back up wrong from TB, I went to do a restore and RA told me there was no recovery.
I tried a different recovery file and same thing.
I had to re-wipe everything and reflash and then install apps one by one. I was up til 3:30 am doing this crap!! What did I do wrong? Where are my recoveries? I went into the nandroid folder and they were there, they even showed up in my recovery files when I tried to flash them but it tells me to see the log. Where is the log? How do I get my recoveries back in case something goes wrong? I really don't want to go back to CWM to get the older ones as I've read CWM is not that good. Help please and thank you.
I tried a different recovery file and same thing.I had to re-wipe everything and reflash and then install apps one by one. I was up til 3:30 am doing this crap!! What did I do wrong? Where are my recoveries? I went into the nandroid folder and they were there, they even showed up in my recovery files when I tried to flash them but it tells me to see the log. Where is the log? How do I get my recoveries back in case something goes wrong? I really don't want to go back to CWM to get the older ones as I've read CWM is not that good. Help please and thank you.
but maybe go check out themikmik forums, I am sure some people over there can answer that for you
