thaprinze
I've gotta say, the only thing I have a problem with in Android is the appointment reminders that pop-up. For anyone who's used WM or Outlook, you know that when your appointment reminder pops up, you have the option to either snooze it for a pre-determined amount of time, or just select how long you'd like to snooze it for (10 mins, 30 mins, 1 day, etc.) With Android, I only see the options to snooze a default amount of time (5 mins, I believe) or dismiss the appointment reminder all together.
Anyone know if that's just how it is, or if you can define how long you'd like the put off the reminder? Thanks!
