What is it?
offanairplane
Under the battery door, to the right of the camera lense, there is a little rubber cover. If you remove it, you see two little brass-colored connectors. What is that for? External antenna? Seems like a kind of inconvenient place if that's what it is. Anyone know?
Don't know for sure, but here is an image (upside down) showing those ports or connectors:
Google Image Result for http://runaroundaroo.files.wordpress.com/2010/11/dsc015411.jpg
Here's the website that I found that image in:
http://runaroundaroo.wordpress.com/2010/11/02/i-so-smart/
Maybe test / reset ports? You can see the connections these ports make with the other parts of the phone.
Cheers!
I so smart…. Run-around-aroo
Cheers!
Cool!
Not only did it give me a picture of the wiring of these ports, but it also made me aware of the fact that replacing my screen can be done easily and cheaply, if I ever need to. Bonus! :)
I zoomed in and focused on the port area, and circled the ports.
The black thing underneath is the headphone jack I believe. Not sure about the little squares to the left. Light sensors? LED's?
That is an annoyingly vague thread title but I've always wondered what it is.
Right! Because if it were just a couple of ports on the circuit board, you wouldn't think twice about it. But since HTC went to all the trouble of making a little rubber cover for them, for easy access, it's gotta be something useful.
I wonder if maybe that is how they program a bricked phone?
