chillenandy321
Member
What profiles are you using everyone please help.. Thanks
Meltz014,
what kernel? i was under the impressing the fresh stock kernel (w/havs) didn't play nice with profiles. are you not having issues? have you tried a run WITHOUT profiles to see if there is an improvement in life?
I am using fresh and a netarchy kernel but have stayed away from profiles due to all the warnings
Pardon my ignorance here:
SetCPU needs to be running in the background for it to do it's job I'm assuming here. If I do a bunch of other things it can be killed by the OS correct? So I need to make sure it's on every once in awhile?
Sorry I'm new with rooting and wanted to get some insight here. Thanks for your patience and any clarity you can give.![]()
Meltz014,
I am using fresh and a netarchy kernal but have stayed away from profiles due to all the warnings
Oh ok, so I use that Priority slider in the app to make sure it doesn't get killed. I think I'm getting this now.It has a setting that trays to prevent itself from being forced closed by the low priority setting in the device. You shouldn't really have to worry about it much, But it is recommended you can keep an eye on to make sure. No worries though.
