I am new to tasker.
Is it possible to create a task that will stop sms text from coming into my phone afer certain time of day or from a group or contacts.
If so can you point me on how to set up.
Thanks in advance
joehornback
This is what i would like to do. Can you list how you programmed it. Ive tried but cant seem to get it to work.
thanks
I've been having some serious issues with using Tasker's lock feature (the one that utilizes the pattern lock).
I have three profiles setup for this. Home, Class, and Car, where the lock is supposed to be deactivated, and then reactivated when I leave.
However, they are never consistent. Tasker will recognize that I have entered the class or home profile, and deactivate the lock. But then, later, the lock will activate again, and no amount of entering/exiting or enabling/disabling the profiles will get it to deactivate the lock! I then have to restart the phone to get Tasker back on track.
Anyone have a tip on a way to remedy this problem? Thank you.
Hi I'm having a tough time. here is all I want tasker to do for .
I have a car dock. So when my phone is placed into the car dock I want to launch BT settings and them connect to my BT receiver in my car.
So... place phone in dock....open BT settings-- and choose my BT receiver for my car. connect to the adpater. Once it's connected power amp takes over and start playing my music.
Any help? TIA
Just set one up so that when my phone picks up my work wifi, it automatically fires up my PC
joehornback
thanks for the help on silencing the incoming text from google voice.
I also created a profile on a schedule time to remove the google voice text notification on the notification bar. This way any text comes in from google voice, the first profile silences it and the next profile removes it from the notification bar. This way i can keep my google voice text(work text) from notifying me.
It also silences regular texts but it still provide a notification via vibrate.
Anyone want to know how i set it up let me know.
lol I have the Imperial March for my ringtone.4) Battery level at 20% it states to plug in the charger and plays imperial march
http://www.youtube.com/watch?v=NyA_Q40FuUw
After 2.0.1 I think AdamG removed the Oxygen settings, in CM7 it's in the CM7 settings section. Oxygen also lost the trackball wake function, which is mostly why I stopped using Oxygen.Hey, guys!
1. I'm still trying to figure out how to make the ringer volume go down (for example by half) when I pick up the phone. (HTC Desire has this feature embedded, but I'm on Oxygen now =)
Is it possible?
2. Moreover, stock HTC Desire can mute the incoming call when you turn the phone over. Is it possible to do the same with Tasker?
Thanks! A step-by-step guide will be really good =)
