Simba501
Headphones plugged in - Vibrate mode, media volume changes to 5 (to protect ears), display turns on (so I can quickly proceed to the media I was going to), auto-brightness turns on (for when I'm going outside and my normally dim display makes it hard to change songs)
....on exit - media volume changes to 0 and auto-brightness turns off
Incoming Call - In call volume goes to the max
....on exit - media volume changes to 0 (for when I was playing music and forget - the music continues to play, but doesn't blast when I hang up the call)
Received text - display turns on
App (Call confirm) - (on exit) - in call volumes goes to the max
Gmail notification - display turns on
USB Plugged in - display turns on, widgetlocker unlocks, status bar expands (to quickly access sd mounting - my default usb connection is "charge-only"), and after 10 seconds the status bar collapses again (in situations when I'm not sd mounting) and my device locks (widgetlocker)
Calendar notification - display turns on
App (Clock) - Load app (alarm clock plus) (so I can use the stock HTC clock/weather widget, hit the time and go to the alarm clock of my choice)
App (gallery) - load app (quickpic) (so I can go to the picture app of my choice when in the camera)
device shutdown - silent mode on (to silence boot sounds)
