Do you need to know programing language or is Tasker easy to use? I'm thinking about getting this app. Is there a place that has profiles already made to basically copy another profile that someone has written?
Neither. I don't know a single programming user, and I use Tasker just fine. It is not, however, easy to use. It's all GUI-driven, but the interface is a bit clunky and counter-intuitive. Once you get used to using it, though, you realize it's quite powerful.Do you need to know programing language or is Tasker easy to use?
Yes.I'm thinking about getting this app. Is there a place that has profiles already made to basically copy another profile that someone has written?
You set WiFi to off, but you never set it to on.2. Online Apps
Context: Application - Internet/Youtube
Tasks:
Variable Set - %Internet To 1
Exit Tasks:
Variable Set - %Internet To 0
WiFi - Set Off
I dont know if these are correct, but it wont work properly.
I open the browser but it wont open the WiFi and uses only 3g.
I checked that the Online Apps works, when i open the Internet?
In my galaxy s2 the internet app is called Internet.Is there really an application called Internet?
Hi guys
I could really use some input how to set up a profile, that auto activates Bluetooth, when I'm driving. But I would like the profile to activate, when I begin driving. I've been trying different settings, but havn't come up with a profile, that forfils this task.
My gues for a profile is, if possible, if Tasker can monitor if GSM cell changes, then it should turn ON Bluetooth. That would be (I gues) an almost non battery usage profile, as a substitute for a GPS profile. As far as possible, I would like not to use GPS because of the higher battery usage. Also the profile should only stay active for a given period, if there are no connection to my Bluetooth device (radio).
Is this possible?
Regards
Frank
Denmark
Why not just get a car charger (imo, doesn't make sense not to have one, especially if using navigation.) This way you can set profile to turn on when connected to carcharger with the "if not at home" or work etc wherever else using charger. I have a pop up when I plug charger on that allows to to switch profiles to car, work, home etc.
I know this doesn't answer your question.but im not sure how you would do what your asking. The cell near is easy enough but that would mean whenever you left any chosen area (home etc) Bluetooth would switch on regardless of in car or not, even if you had it turn off after no bt connection, it would still be on for a period of battery drain time. I once play with an idea of car profile changing once travelling over a certain speed but only managed to find out how to convert speed onto mph from httpget data. Sorry can't be more help
You could create your own function to trigger a reaction to cell changes by comparing current cell id to the last cell id (stored in a user variable). I use this approach to pickup new cells that I need to add to my location dependent profiles.
However this would fire very often and be a potential processor/ battery hog in high cell density areas.
Personally I use an NFC tag in the car to toggle bluetooth.
What does NFC stand for? No F..... Clue![]()
Near Field Communication... Nexus S and Galaxy Nexus have it, most phones released from here on out should have it. It is going to become a basic feature of every phone.
One minor problem is that the gestures don't appear to be sensed unless the screen is turned on. Is there any way to get around that?
Hold your finger on the entry task and a context menu will pop up asking you for an exit task.I am having an impossible time trying to find how to add an 'exit task'.
I can't find ANY option to add an 'exit task' anywhere after making a profile.
