How can I do this? I want Spotify to shutdown at midnight and not drain the whole night.
Yes, it does turn my GPS on and off.![]()
It depends. First of all, what do you mean by "when I go onto the internet"? Like when you open your web browser? Secondly, is there, in fact, a setting on your phone to switch between LTE and 4G/3G?Hi,
Anyone know how to setup a profile using tasker so that when I go onto the internet, the LTE mobile mode is selected? When I am not on the internet, either go back to 4G or even 3G for other apps. Keeping the mobile mode on LTE really drains the battery. Don't need it on all the time.
Thanks,
Matnick
Are you on Gingerbread because it doesn't allow to turn GPS on or off. How do you do it?
Hi,
I have a Motorola Droid Bionic and I have Gingerbread version 5.5.893 stock (non-rooted).
I have several apps, such as Maps, Trapster & Nav set to turn GPS ON when those apps are started and as an "exit task", to shut OFF GPS. Been working fine for me.
I can't shut off APPS with Tasker in Gingerbread so I have Tasker VERBALLY tell me to shut off those apps.
Hi,
I have a question regarding profiles that are for certain days.
I have a 'work' profile set up which will kill all internet at a certain time (8:50pm), dim the screen and turn vibrate on and will turn off again the next morning (6:00am)...I want this only for monday night to saturday morning. But when I tried to set it up to work for certain days it would mess up and create a second profile or context where it was 8:50 - 0:00 which was ok, but then would screw up the next one which you would think would be 0:00 - 06:00...it would be from unknown time to 11:00..
so is there anyway to properly do the days thing or would I have to create a second task to do this?
I posted this before, but I still need help: I have a silent profile for when at work, I want 2 contacts to ring even when silence. I got it to work for when the contacts call me but I can't figure out how to do it when a text is sent. Also, this is minor but when the contacts call the general ring tone rings and not their special ring tone.
Re GPS on/off problems:
On my Desire I have GPS enabled all the time via a toggle BUT it doesn't kick in until a program needs it. For example if I start Navigation the GPS switches on and when I come out of Navigation GPS switches off. I have not noticed that this affects battery life at all. I used to try to handle this via Tasker but ran in to the same problems as outlined above. So perhaps you don't need Tasker to handle GPS at all?
I hope I have understood the problem correctly!
GPS never shows up in my battery settings so I think that that confirms that it doesn't use battery unless a program is using it. I continue to leave it switched on (using Widgetsoid to keep a check on it) and programs using GPS cause it to turn on (as seen at the top of the screen) and then off when I quit them.
Would GPS show up in the battery report. I would have expected it to be the application that is using it? Just a guess??
