deanshep85
Android Expert
Right I got a toughy, well maybe its not for the experienced..
I have 4 profiles set right now on my phone...
- Wifi on/off through Location (home)..changing as well to 3G when out of the 'home' location...and changing the background to a darker background when outside so its more visible and back to colourful when home..
- GPS on/off when I launch GPS needed applications..
- Games turning wifi on/off when launching (needed for advert filled games to get rid of them)
- Battery 20% shutting all wireless connections and turning brightness down to 30% as well as changing background to black to lower consumption.
Now my first question is this...I would like the 'Games' profile to turn on/off the wifi AND 3G Data depending on the status of the first profile 'Wifi on/off'...For example, if im at home I want to play say angry birds it will turn off Wifi, which I have on at home and turn it back on after I finished playing...BUT I want it to also do the same when outside the 'Home' location with 3G data...
I did put in the "Data on/off" task in the same profile, but it does this weird switching back and forth between wifi and normal data connection when I finished playing the game...this normal? can what I want be done?
And now for my second question...I want to have a 5th profile to have ALL wireless connections...wifi,data,gps etc OFF between midnight and 08:30 am and switch either wifi *OR* data back on depending on the location (refer to first profile with home location) and to also have a different 'night' background during this time as well...so for example, if im at home I want it to switch back to wifi at 08:31am and if im not at home then to switch to data at 08:31..
is it possible?
is it possible?
