Neon Mirage
Trigger:
Shake Up and Down
Action:
Turn Bluetooth ON
Flash Notification 'Bluetooth ON'
Shake Up and Down
Action:
Turn Bluetooth ON
I don't suppose you can export those profiles? I'd absolutely love to have my phone do something like this when I'm near home/friends wifi without the huge battery drain!First, Kudos to all who have contributed to this thread!
I stumbled onto Tasker a couple weeks ago, then I found this thread and have had it up on my screen reading at my leisure for most of 2 weeks (2 years worth of postings!). When I was about 2 pages into it, I purchased Tasker and have been fooling around with it during the time I was reading this thread. Now that I finally finished reading, I just had to join the forum and post what I have been doing with it.
And what happens when you manually turn wifi on/off?
Ahhh I see, that's great hahaha! Some handy info there, thanks for the replyDoesn't matter if wifi is off. (I pretty much leave it off.) The "pinger" will toggle it on for a few seconds then toggle it back off (toggle option works great here). You can set how often it toggles wifi in the "monitor" preferences. I did a similar thing with a "bluetooth" pinger - periodically check for some non-existent connection. Then use "wifi on" or "bluetooth on" contexts to do the actual work. That way several things can check "wifi near" without toggling wifi again (just checks the variable containing the last seen wifi info).
Another nice addition was a task called "Talk" that takes arguments as to what to say, etc. That way you can set the "Say" variables consistently so the voice always sounds the same. Also, I can change what stream to speak on. When connected to my bluetooth in my car, no media can be heard so I always "Talk" on the notification stream.
Once in a while when I'm bored, I'll scan for Cell Near and put a blurb in. Now when driving around, my phone occasionally asks "Are we near the dam?" or "Are you going to get your hair cut?".
The other day I was in a checkout line and got a text from my wife and it read it out loud. Everyone around got a kick out of that. I'm just glad she was only updating my shopping list!![]()
I've been using Tasker for quite a while now, and use a number of Tasker profiles, and a whole bunch of Tasks that interact with other apps.
Profiles:
1. Phone Hang Up -> Go to contacts app (bypasses Galaxy S3 function of displaying the contact on the previous call)
2. Receive call when Google Maps (Navigation) is open -> Return to Maps after call (good for hands-free in the car)
3. Power AC -> Bluetooth On (for activating Bluetooth when plugged in in-car)
4. Launch Bluetooth dialer (Cyberon) when Google Maps is open -> Return to Maps after call
Tasks for other implementations:
1. Play, Pause, Next Track, Previous Track tasks - Activated by a WidgetLocker slider (ICS lock-ring style) on lock screen. Good for controlling Poweramp in the car without having to unlock my phone.
2. Display Emergency Contacts as Popup Task Buttons. Popup is launched by a Minimalist Text Widget labeled "Emergency Contacts" on WidgetLocker lock screen. Popup Task Buttons are labeled with emergency contact name and phone number.
3. Call Emergency Contact (as displayed on Popup Task Buttons). Enables first responders, etc to call emergency contacts without having to unlock phone (which is PIN-locked).
4. Various tasks toggling settings (ringer volume, media volume, screen brightness, Wifi, Bluetooth). Activated using SwipePad app. Allows me to swipe upward from the bottom of my screen (in any app) and quickly change settings. Removes the need for a settings widget and makes settings accessible without exiting to home screen.
I think we should get a good thread going with how everyone has set up profiles in Tasker. With so many options, sometimes I overlook a really cool way to set up a profile. Here is what I have, post yours:
1. Bedtime
Context -
Time: 2130-0300
Orientation: Left Side
Power: Plugged in
Tasks -
Media Volume set
Load app - White noise
Wait - 5 seconds
Load app - digital clock
2. Quite Clock
Context - same as above but time until 1000
Tasks - Notification volume - set
Exit task - notification volume set
3. Car
Context - Bluetooth connected
Tasks -
Media volume set
Wifi off
Exit tasks -
Bluetooth off
Wifi off
4. Call
Context - Incoming call
Tasks -
Auto brightness on IF %CNUM !~ 0
Ringer volume set to 0 IF %CNUM ~ 0
Wait 45 seconds
Auto brightness off
Ringer volume set 15
That is mine except for a few really basic ones. There is still 1 I want to set up:
-Face down at a certain time -> screen lock, otherwise no lock, alarm triggered until unlocked if picked up.
So what is everyone else doing?
First of all. Welcome buy you are in the wrong place. As the title says thus isn't a guide side, it's for sharing. There are tons of step by step guides out there and if you need a place to start, Lifehacker has some pretty thorough guides on YouTube.Hi everyone,
I just bought Tasker (waits for everyone to say "Finally!"), so I'm going to ask some pretty obvious questions:
- Firstly, how do I change from the UI form of adding a profile to the coding form?
- I'd like to create a profile that warns me (by notification sound or similar) that my alarm is active if I have a calendar entry that will be occurring in the upcoming 10 minutes. Is there any way of automatically turning said alarm off if this occurs?
- I've created a simple profile using the UI that silences my phone whenever I have an active calendar entry. However, when I press volume up or volume down (SGS), at least in the test mode, it un-silences my phone. Is there a way of getting a confirmation box pop-up asking me whether or not I really want to un-silence my phone?
- I looked at the Tasker Wiki site, and have absolutely no idea where to start. Where can I go to find information on what each piece of code that I see on the forums actually means?
Thankyou =)
God bless.
