Root which kernel is better?
homeless was made for better battery life, and speed, well is made for speed. Depends what you want
I've only used the plague kernel so it's the only one I can account for. I've heard good things about homeless but my phone is great as it is so I'd rather not change it.
plague was the first kernel i used. I liked it a lot but when i overclock to about 1.8/1.9 my phone would heat up to about 107F. Not too bad but the battery life sucked. Im running the speed kernel now and its fast, easy on the battery, and doesnt heat up at all
you tried GSE II with the plague kernel which has the homeless settings too??? ;)
I underclock to 600 so I don't worry about that. :D
You don't have to be all the time at 1.8/1.9. You can set a speed less than that but higher than stock.
That is like buying a Ferrari and driving all the time at 15 MPH, something a little bit weird but of course is your choice.
