Thanks for the response. However, the option is greyed out/un-selectable.![]()
Oh... you probably don't have your SD card partitioned. Reboot into Recovery mode, then Partition SD card (just use default values). After that, do the ext2 to ext3 option. Then do your wipe and dalvik wipe (just to be safe? not sure if this is necessary) and flash your ROM again. I think it should work after that.
