Root Why no Rotation Animation?
Every phone that I've put a custom ROM on has the ability to perform this...except this phone...hell if my Samsung Admire, HTC EVO 4g and even my old asss G1 are able to do this then what's stopping a phone that's better and faster from doing this? .why isn't this getting built into every Esteem rom? Does it cause issues or what ? I wants it bad
u mean like this?
or transition effects?
Are u watching the video or just looking at the pic? Cuz mine is set to "on"....it changes but without the transition animation
ahhhh. I see what you are saying now.
What phones did you say you had this on? Not all ICS phones right?>
I think Lg lacks that function but i might be wrong but perhaps with go launcher and other laucnhers maybe u could enable it to do that??
I've never actually noticed. Although i keep it off anyways. I have no use for it. More battery for me :D
Plus it becomes very annoying when it changes when you dont want it too. Many a times ive almost thrown my phone out of aggravation because of it. hahaha
Same here im too simple perhaps i dont bother with widgets or transition effects, lol
i dont give 2 cents about rotation animation or what not, just wondering what would you benefit from getting, do you just turn the screen just to see animation? Not being rude or nothing just curious. ;)
And best way to disable the annoying screen rotation is to disable it from the launcher your using and no the phone itself, just in case you want to text it will still rotate on the apps, just not the home launcher your currently running.
Me either. I have ONE widgit and thats the ICS google search bar and its more for looks than anything else. ahahahaha
To me, opening a widgit is the same as just opening the damn app by itself. lol Bump that ish. Ill keep my battery. :D
amen to that, it only takes a split second to open the app drawer and tap that app, ok that didnt sound right, bahahaha
Would like the entire system to do this not just launcher
that would have to come from lg, think of HTC phones with Sense that HTC built for there device. Im not saying it cant be done, but building something like that without no source is no good, and can possibly cause problems with other features the phone comes with.
i dont know why ppl respond like this...if it doesnt apply let it fly ....no disrespect but i dont give two cents about your opinion...im looking for a solution, not your commentary...once again no offense...i hate that i just contributed to waisting server space...
don't you need some type of Cyanogenmod to have that? My old Admire has CM7 and has that rotation ani. That LG phone looks like it has CM, I could be wrong tho.
Ok seems you have answered your question and that question is there a rom or a mod that exist for the Lg esteem that will enable such transition effects? the answer is no! can it be done? yes! when will u be able to see this? no telling then unless u post on idrfita or pg's thread and tell u what since this more of a mod than a rom or kernel issue u probaly can get shiny to look into to this and make a small mod for it. lol but who knows he might have spare time and nothing else to do. just ask him nicely :D
yeah i already pm'd both PG and Idrifta before you even posted this...nothing yet
well they do more sophisticated things like kernel and roms try to reach shiny thats more his alley
Good!!! lol ;)
I looked in the framework, res_cap and systemui and couldnt find anything for screen orientation animations
my question is did it do it on stock or CM on your other devices?? And like I replied to your PM, no I wont be trying to write it in if its not there by default. ;)
