I have the huawei ascend and every time I try connecting to my wi-fi I get this message "Disabled, secured with WPA/WPA2 PSK" but the phone connects to the wi fi at a friends house.... How do I fix this? Thanks![]()
I already typed my password in, it just doesn't connect![]()
tap you wifi name and tap forget, than restart the phone and try connecting again, also you may need to restart your router, btw what router do you have?
CISCO Linksys.tap you wifi name and tap forget, than restart the phone and try connecting again, also you may need to restart your router, btw what router do you have?
do you have mac filtering enabled too? if so you need to add your phones mac address.CISCO Linksys.
if that doesn't work disable encryption and mac filtering and see if it connects then and if it does then re-enable security and setup your phone for it n see if it connects.
How do I get the MAC address?
Hey, Toke, long time no see! Glad to see you back!Menu button.... settings... about phone... status... third from bottom.
Didn't work :'( any other suggestions?
check the website for you router and see if it has a firmware update, but first check your channel in your router settings and see if its set to auto channel or channel 11.
How do I do that? Lmao..
LINKSYS Cisco WRT120Ngive me the router info cisco linksys e1000 or what?![]()
so what is happening when you try connecting your phone to it? and who is your carrier?
And this might help, but where it says "Wi-Fi" right below there it says "disconnected" and on my network name it says "Disabled, secured with WPA/WPA2 PSK"
