jm4nth3b3st
I have a HTC evo 4g flashed to boost mobile. right now since boost doesnt have 4g it only runs on 3g. coming the 31st boost will have 4g. does anyone know whether or not flashed phones will be able to recieve 4g?
great question! i'm not 100% percent on that one, but yes i believe you should be able to get 4. boost will most likely uses sprint's 4g network so i do not see why you should not be able to get 4g. i have not found any confirmation on this one. this is just my assumption.
I am interested to see if anyone has luck getting there 4G to work after the EVO is released keep this one going ?
Boost and Virgin mobile, prepay brands of sprint will be using wimax as sprint has moved on to lte.If boost uses Sprint's new LTE network (probable)- it will not happen
If they use Sprints Wimax network (less likely)- someone will find a way
